Page 3 of 3
Re: back to the fold. cant bloody help myself!
Posted: Fri Oct 28, 2011 1:06 pm
by Evilchicken0
Told you it was easy :grin:
Iron out some of the gremlins than you can do the valves later, but hey well done
Posted: Fri Oct 28, 2011 9:05 pm
by kaighn80
just to prove it here it is,
the exhaust fits a bit better having used the tried and tested method of sticking a pole in it and standing on the pole whilst gently bouncing up and down whist simultaneously pushing on the bike so it doesn't topple over, and the tank cover fits, I've since pulled the carbs off and cleaned them, number 4 was green and cruddy the other 3 seemed OK but i cleaned them out anyway, so balancing them tomorrow and hopefully they should be good to go, I've kept the exup not sure if it will help or hinder but it works so I'll see if it helps with midrange.
Posted: Sat Oct 29, 2011 1:12 pm
by kaighn80
right, having stripped the carbs down to their component forms I've got them cleaned and rebuilt and it runs nice, had a lot of white smoke but that cleared and she now idles nice around 1200rpm, haven't been able to balance the carbs but I'll do that as and when i can. so its now a case of fitting the air box on properly and fitting the bodywork then I'll take it for an mot and see how she does.
Posted: Sat Oct 29, 2011 6:40 pm
by Evilchicken0
That's sounding suspiciously like you've got a running bike :o
Nice one - not so far away from an MOT :grin:
Posted: Thu Nov 03, 2011 4:20 pm
by kaighn80
right as i dont need the 400 bits and bobs, does anyone want anything before it goes on ebay?
