only getting 12.10 volts when running
hallsie
Bike owned: NC29
Post by hallsie »
Alternator is knackered , went through all this with my cbr !
kate beckinsale....... mmmmmmm
jetblack
Bike owned: '89 NC30 SEED
Re: only getting 12.10 volts when running
Post by jetblack »
Just ordered one off GF. hopefully this will sort me out.
Have just tried to make my own locking tool. Failed. Metal i had was too soft and it was just moving round when i tried to turn the central nut. Any tips?
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti »
jetblack wrote:Just ordered one off GF. hopefully this will sort me out.
You only need to change the windings, not the flywheel!
jetblack
Post by jetblack »
Yeah. But I need to get to the windings....which are behind the flywheel.Non?
amorti
Regular Member
Post by amorti »
jetblack wrote:Yeah. But I need to get to the windings....which are behind the flywheel.Non?
Ah, comprende.
The best bet is to use an impact driver. Shocks it right off even if you can't figure out a holder mechanism.
jetblack
Post by jetblack »
Hallsie, looks like you were right...
Got the flywheel off and found this waiting for me inside.
Replacement on its way.
SNAP!
jetblack
Post by jetblack »
So, i'm intreigued to know how this happens. Can anyone clarfiy whats gone on for me?
Bike owned: VFR400
Post by magg »
Just a comment on an earlier post in this thread, the statement "So you just stick one probe in 1 of the 3 slots in the alternator plug and the other probe in any of the other slots on the connector to get the voltage?" is correct, the reply "Set the multi meter to volts then but the black lead on the battery earth and the red lead to each of the 3 yellow wires." contradictes an earlier post and is incorrect. The alternator output is only between the three yellow wires & should be measured without the rectifier/regulator disconnected to get a true indication of the output AC voltage when using a multimeter set to AC volts. Voltage measurements between the yellow wires & battery earth or between the three yellow wires with the rectifier/reguator connected will give a voltage reading that will vary depending on the type of multimeter but will never exceed the battery charge voltage by more than a couple of volts.
Bike owned: VFR400
Post by magg »
My previous post had an error, the rectifier/regulator must be DISCONNECTED when measuring the alternator ouput voltage.
