Style dilema!! Endurance related
- ibby4585
- Bike owned: SP's
Re: Style dilema!! Endurance related
Stephen ive just seen your RVF build on PB for the first time and I have to say mate that is the most stunning bike I've ever seen, just awesome. It kinda makes my OKI endurance copy look cheap and trashy!
Cheers pal, i did borrow roysters a while ago and took some templates from them but they turned out to be slightly different but your nose cone is the same style as mine so theres a chance there the same.ibby4585 wrote:You can borrow my Amber silhouette one mate if you want a template!
Isnt yours lime green tho? doesnt matter obviously just splitting hairs
yes please kris, or are you offering that to tony?ibby4585 wrote:You can borrow my Amber silhouette one mate if you want a template!
editporndoguk wrote:yes please kris, or are you offering that to tony?ibby4585 wrote:You can borrow my Amber silhouette one mate if you want a template!
tony can you draw around it for me and post me a copy of it dude
cheers ears
Ricky, they wont fit pal, take a look at the silhouette nosecones, they have a recessed section around the lights for the covers to sit, the standard nosecone's dont have this plus are slightly different shaped all together.
To make a set for the standard nosecone should be dead easy, ive got one here i'll have a go with the stuff i have have here tomorrow if you want.
- ibby4585
- Bike owned: SP's
Drunkn Munky wrote:Cheers pal, i did borrow roysters a while ago and took some templates from them but they turned out to be slightly different but your nose cone is the same style as mine so theres a chance there the same.ibby4585 wrote:You can borrow my Amber silhouette one mate if you want a template!
I can't believe I actually had to check! Yes acid green it's called will pop it in the post pal.
Kris
please just wanted a rough shape to follow,Drunkn Munky wrote:Ricky, they wont fit pal, take a look at the silhouette nosecones, they have a recessed section around the lights for the covers to sit, the standard nosecone's dont have this plus are slightly different shaped all together.
i know theres no recesses etc, but wanted the diamond shaped cover thers not gonna be flush fitted there going to be surface mounted so the lense will stick up whatever thickness i go for, thinest seems to be 3mm orange perspex on ebay,
need to get 1mm really.
Ricky i'll send you the lenses i made from roysters silhouette nosecone, you can either fit em straight on or use them as templates. There 1mm lexon similar to stephens RC45 shown in the pic.
PM me your addy again dude
Thanks Tony, pm on its wayDrunkn Munky wrote:Ricky i'll send you the lenses i made from roysters silhouette nosecone, you can either fit em straight on or use them as templates. There 1mm lexon similar to stephens RC45 shown in the pic.
- Micro Monkey
- Bike owned: CG125, RVF400, YZF1000SP, 996
1mm sheets are widely available on the net. i have always used gfgplasticfabricationsltd on ebay for my polycarbonate needs.
