Page 3 of 20
Re: Valve Clearance Guide
Posted: Mon Oct 06, 2008 1:06 pm
the exhaust is at the front of the front head. Where the pipes come out??
The carbs enter between the V...so the inlets are the middle two sets of valves and cams - if that makes sense?
Posted: Mon Oct 06, 2008 1:25 pm
by viper_biker
The INLETS are where the fuel goes IN and the OUTLETS are where the exhaust gases go OUT.
Posted: Tue Oct 07, 2008 5:12 pm
by maciekmaciek19
Thanks guys.
Just measured the gaps. All exhaust valves seem to clear ok. 6 inlet are out of limit but the gaps are below the spec - they are too slim - 0.8 -0.10 mm. Does that sound right? I thought the gaps would be getting bigger not smaller...
Posted: Tue Oct 07, 2008 5:15 pm
by spooky
Arn't the 21's & 24's a different firing order than the 30? What do you do about that when following vipers guide? :?: :?:
Posted: Tue Oct 07, 2008 5:19 pm
by maciekmaciek19
Not an expert as only did it once on my NC35 but I think you can't really confuse the cylinders while measuring valve clearance. The feeler gauge will not stick in if the cyl is not in TDM position... This may well be crap though.
Posted: Tue Oct 07, 2008 5:33 pm
spooky wrote:Arn't the 21's & 24's a different firing order than the 30? What do you do about that when following vipers guide? :?: :?:
you should still have the marks on the camshafts and the timing cover. It will be different amount of turns to get it to TDC
you can figure it out from this
http://i100.photobucket.com/albums/m38/ ... kshaft.jpg" onclick="window.open(this.href);return false;
Posted: Tue Oct 07, 2008 7:00 pm
by fastdruid
Easiest way is to just look at the position of the cams on the first cylinder then just make sure the others look the same when you measure them. Note however that this is different between different bikes.
I can't recall what the NC30/35 position is but normally they'll be something like 45degrees to vertical (from the head) and pointing up and out.
Druid
Posted: Sun Oct 12, 2008 12:27 am
by katana
Can i ask how do you replace the shims?
Posted: Sun Oct 12, 2008 12:39 am
by fastdruid
Get one of those magnet on a stick things. Push the rockers to one side and use the magnet to remove the shim.
I tend to use some foil to block the tunnels so that even if I drop a shim it wont fall into the engine.
Druid
Posted: Sun Oct 12, 2008 3:16 pm
by katana
fastdruid wrote:Get one of those magnet on a stick things. Push the rockers to one side and use the magnet to remove the shim.
Druid
Thanks I think I'll do that during the day not at night.
