NC30 wont start
Re: NC30 wont start
there is only pipe onone of the small nipples the one pointing down and this goes to the right hand side of the carb. see pic
http://i249.photobucket.com/albums/gg20 ... 2d1662.jpg
so is there ment to be a pipe on each nipple
Re: NC30 wont start
that is not the right pipe - so put it on the other one and you will have a bike that works...
the nipple it is on is to drain the tap. That does not have a pipe
the one pointing forwards is the one you have the pipe on -- if you imagine sucking the rubber diaphragm in the tap open you pull it from the furthest side - give it a go and let us know..
Re: NC30 wont start
Right played with the vac pipe and i am getting fuel to the carbs now :) i removed the pipe from the tap and cranked it over and when i moved the pipe to the one on the right fuel flowed but uts still not fireing i think the carbs mite be dry now, is it best to crank it with full choke and no throttle til it starts ir should i try to put fuel into the carbs
Re: NC30 wont start
give it a few goes on the starter and let the carbs get some fuel.
Prob go for some choke, check kill switch
, and then see if you can get it going.
Don't be tempted to give it the berries as the plugs might be fecked anyways...but I reckon you'll have it started soon enough.
Just be patient...a few tickles and some choke and then a few longer bursts..hopefully it will start and be your mate again
Re: NC30 wont start
Will give that a go, i have some new plugs on there way too
Re: NC30 wont start
well its getting fuel now as the plugs are wet so will wack them in when they turn up and cross my fingers
Re: NC30 wont start
cool - but try getting your current plugs dried off on your hob if it is a gas one...give the tips a good flaming!
might get it going..as if it floods the next set they'll possibly turn over and die too...
Re: NC30 wont start
good idea but we have eletric cooker at home, i guess i could stick them in the oven for a while when mum has gone to workCMSMJ1 wrote:cool - but try getting your current plugs dried off on your hob if it is a gas one...give the tips a good flaming!
- Bike owned: NC30+VFR750
Re: NC30 wont start
why wait until your mum has gone to work????????
Re: NC30 wont start
i said about doin that and she wernt happyHissing sid wrote:why wait until your mum has gone to work????????
