Posted: Sun Mar 02, 2014 9:45 am
"A goal without a deadline is a dream"
Screw it, on Friday I booked some track time on Sunday (today) and figured I would go into the garage and do whatever was required to get the bike track ready. One of those things, it didn't seem like much .. but it was a 13 hour day getting stuff together and ready.
Things like - cut and fit new chain, go over bike slowly and tighten/torque things, get a spacer machined for the HRC linkage and adjustable pull arm and get it finished, get the bike started, refit exhaust system so I got more rear wheel clearance, adjust clutch, lock wire things, etc etc etc ...
It took ages, but I got there and then went to bed - for a 5am start the next day. Geeez.
Stuff like ...
This doesn't look good. Carb not in far enough when reassembling after carb syc:
Better .. :
I finally settled on butchering a pull arm bearing sleeve for the spacer at the top of the adjustable pull arm assembly. Cost me a bottle of wine to get a friend to machine 14mm off either end to come up with a 77mm spacer:
After fitment of adjustable pull arm with a length of 130mm eye to eye (3mm longer than RO HRC item), clearance is good:
New DID 520 VT2 chain cut to 106 links for 14/43 sprocket combo. By the way, the VT2 is a 520 motocross *race* x ring chain. It is lightweight and strong and a perfect match for the power of the 400 - it is also MUCH cheaper than buying a 'race' chain for road racing. Seriously, like 50% of the cost or so. Great chain though.
Here is great and very cheap way to get your master link pushed though - put a nut over the end it comes though and squeeze with a pair of adjustable pliers - works a treat.
You know when you have it pushed through enough when you can get the clip and push it into the groove - it you cannot, squeeze some more other wise you'll not have a groove for the clip link to slot in to and you likely break the clip trying to get it on .... I have before. Don't squeeze too much - keep checking the clip/groove thing.
Round end faces direction of travel:
And VERY importantly ... lock wire it on:
On holidays once I lost my clip link (and luckily realised it pretty soon). Some ordinary paperclip wire fit into the master link groove and I then wired it on (like above) with more paperclip wire. It lasted 2000klms over christmas holidays and got me home. Nice eh. Dont trust the link, trust the lockwire!
and speaking of lockwire ... lots of that to be done here and there:
I can't recall if I mentioned, but I was having serious clearance issues with the 'Ethos' exhaust system and the rear wheel - one of the reasons for going to 106 links with the 14/43 sprocket combo.
So, I loosened up the entire exhaust and, after getting the chain on and HRC linkage (etc) fitted I held the exhaust system in a position that gave me clearance and *then* tightened things up. Viola!:
After much toil and 5 months or so of dicking about ..
A "fully operational battle station"
Yes, it looks like sh*t as I haven't done any painting or decals yet, but I need to get it out on the track to shake it down before race season starts ...
Stuff like ...
Better .. :
