xivlia's thread of nc30 problems and questions
Where posts and threads can be moved to future safe keeping.
Locked
Re: bike wont start now? any ideas why?
xivlia wrote:yep got a multimeter. i shall test it later on :P now i ordered proper gakets for the rear manifold to downpipe...because the copper rings didnt make a seal :\
Did you tighten it up properly? I used 2 copper ones last week without issue.
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
i did tightend it up but if i tighten any harder the clamp just bends from over tightenining
xivlia
Re: rear downpipe gasket.. this is the right ones?
Post by xivlia »
okay i just bought the 18291-mr8-000 part number which is the gaskets for the rear downpipe to manifold...and they look exactly the same as the copper rings except they are dark grey almost brown colour..and a wee bit thicker...is that the right ones? sorry got no pics to show as my phone is broken and i dont have anther camera
xivlia wrote:okay i just bought the 18291-mr8-000 part number which is the gaskets for the rear downpipe to manifold...and they look exactly the same as the copper rings except they are dark grey almost brown colour..and a wee bit thicker...is that the right ones? sorry got no pics to show as my phone is broken and i dont have anther camera
Yes.
The copper ones do work too as i've used them.
If you still can't get a seal you are not doing it right.
Make sure gaskets are in properly. exhaust pipes are nice and central so they can crush up against the copper ring
xivlia
Post by xivlia »
ah okay. il see if i can try and put them in. havent tried yet as im in college at the moment, the other thing is the pipe bracket is a little bent so it wont go into the studs unless i push it quite hard. and i have a feeling that this is causing the downpipes not to sit in centerly.
That shouldn't matter so much, there a little fiddley.
Easiest if you have the rear hanger loose so you can move the exhaust around a bit so you can get the pipes connected properly
xivlia
clutch wont work properly? what the hell?!
Post by xivlia »
okay, so i installed new clutch lever. and now it wont work properly? i tried pressing the lever...and put the bike onto gear 1 from neutral...and the chain starts to spin...okay..but when i let go off the clutch the chain still spins? wtf? the bike wont stall and when i press the lever again and give throttle the chain spins even faster?....what could be the problem....it was working before i removed the lever and put the new one in...and i didnt do any adjustments to the cable at alll..just removed the old lever and put new one in.. please help :(
xivlia
Re: clutch wont work properly? what the hell?!
Post by xivlia »
oh another note..im guessing the clutch is constantly engaged and wont disengage....
missis sumner
Bike owned: NC30 + Teapot
Post by missis sumner »
Have you seen my thread? ;)
viewtopic.php?f=24&t=31148
Did you check it wasn't dragging before you changed the lever - because I didn't, and it was (or at least I've come to the conclusion it must have been).
vfrman
Bike owned: NC30, 1098s
Post by vfrman »
Hard to say. Try to adjust the cable.
Locked
