NC30 rear disc removing question.
Re: NC30 rear disc removing question.
I got a few spare calipers, if you decide you want one ill check it over for you so you can just fit it
- xivlia
- Bike owned: Ducati 749 D
thanks man :) il let you know in a couple of days.
- thunderace
- Bike owned: R6, YZF600R
Where's the popcorn?
This is yet another thread of sound advice being ignored, fuck ups and more fuck ups.
You guys really are salt of the earth with the patience of saints! I gave up long ago.
- xivlia
funny to say, i managed to get the piston out. heated up the area with a bic lighter and pumped the pedal. and away it came. the piston looks very clean, a tiny amount of surface rust.
- bikemonkey
Waheyyy!
Now get it sorted
Now get it sorted
- xivlia
i will need to order a set of seals and red rubber grease. but post offices are shut soooo itl be next week
EDIT
done, ordered a tub of red rubber grease, a tub of copper grease for other stuff, moly lithium for bearings i,e wheel, steering stem etc?? is that right. i ordered some anyway. and piston seals and dust seals.
EDIT
DO NOT USE COPPER GREASE FOR ANYTHING OTHER THAN THE BACKS OF THE BRAKE PADS.xivlia wrote:i will need to order a set of seals and red rubber grease. but post offices are shut soooo itl be next week
EDIT
http://www.jacksons-lair.co.uk/caliper.html
This was written a while ago for the NC24 caliper but the principle still applies to the NC30 caliper as it is the same type.
- xivlia
oh i wasnt planning on using copper grease at all for the brakes. i wanted to keep it for when i take the exhaust pipes off to clean them, i was gonna put the copper grease onto the studs to prevent them from seizing. i was told it is good for that as it is extremely heat resistive.
- VFRkieran
Give the backs of the pads a smear of copper grease, helps with brake squeal and stops the rust from building up. Also give the pins and plugs a good coating with it so they dont seize up, ive just given the brakes on my 800 a good clean, i completly mullered the pin plugs as they hadnt been greased up at all, the rear still needs drilling out and i nearly bent my allen key just getting the pinds undone.
Your going in the right direction with it all mate, buying grease, seals, etc before doing any more shonky cosmetics. Soon you will love your bike and wont want to get an r6, hmmm maybe not
- xivlia
