Page 15 of 18
Re: Can you see what it is yet
Posted: Mon Jan 11, 2016 2:37 am
by Morespeedvicar
Haha.............
The decoke and skim sound like a plan. You just getting them flat or going for a couple a tenths to up the compression a bit?
Posted: Mon Jan 11, 2016 9:59 am
by Evilchicken0
Nah, just flat. It's a roadbike the last thing I want to do is get involved with tighter tolerances.
The cases are away for welding and I've bought a valve spring compressor
Posted: Fri Jan 15, 2016 9:47 pm
by Evilchicken0
Head and Barrels skimmed. I need to clean up the head, pistons, and lap the valves ....
Posted: Mon Feb 08, 2016 1:09 pm
by Evilchicken0
Posted: Mon Feb 08, 2016 2:41 pm
by willandrip
Did you use a dab of grease on the valve stem and surgical forceps to handle the collets Boris. ?
Posted: Mon Feb 08, 2016 4:04 pm
by Evilchicken0
A dab of grease on the valve and a small flat blade screwdriver also with some grease on to place them.
I dropped three of them, one popped out when I was compressing a spring, one stuck to a spring when I put it back, and the last I just dropped.
Posted: Mon Feb 08, 2016 6:01 pm
by willandrip
It's when they ping into your eye when you get proper vexed with the little blighters.
Posted: Mon Feb 08, 2016 7:16 pm
by Evilchicken0
Yes I can imagine they go for the eyes
Posted: Fri Mar 11, 2016 5:18 pm
by Evilchicken0
Posted: Fri Mar 11, 2016 5:27 pm
by Evilchicken0
I laid up the crank to check the clearance from the welds to the flywheel, then practice fitted the lower case, the chain follower needed a bit of guidance. I applied Three Bond with a razor blade to keep it thin - but I forgot the cam chain so had to take it apart clean it all and do it again.
I did remember the oil control though
The water pump and oil pump shafts join (you can see them below the two bolt holes with orange thread lock)
Sump on ...
and starter gears in.
