NC30 Honda Britain rep
- Deviant400
Re: NC30 Honda Britain rep
tony i posted up the vid on page 9 of your thread however it is a sp style but it sits a lot lower and sticks out much more ,
viewtopic.php?f=62&t=27307
- Deviant400
also what have you done to the frame has it been blasted or owt looks like it and is that a standard chopped subby
Ah thats the F1 race so a RC30Deviant400 wrote:tony i posted up the vid on page 9 of your thread however it is a sp style but it sits a lot lower and sticks out much more ,
Nothing done to the frame just a degrease, the rear subframe is standard and chopped as per the race manual. It was then bead blasted, zinc plated then painted.Deviant400 wrote:also what have you done to the frame has it been blasted or owt looks like it and is that a standard chopped subby
- Deviant400
kool looks very clean i thought it had been beaded or summit , very nice
- Tim400GB
Looking good mate.
You managed to contact TS yet? And/or Phil?
Mo has emailed phil but not got round to contacting TS yet, my bank balance needs to be a bit healthier before commiting to having the motor done. The spare motor is shimmed up and fitted today so its progressing.
More shinny bits arrived back and its starting to go together......slowly
I finally got the bastard swingarm needle bearing out for the second time today so once mr silver delivers a new one i shall attempt to fit it without wrecking it again and the rear end can go on with the HRC RS axle :)
- mo haggs
- Bike owned: bikeless
Putting those sma tins to good use already i see tony.
- Deviant400
i spotted themmo haggs wrote:Putting those sma tins to good use already i see tony.
