Cosworth 57mm Pistons HAVE ARRIVED
g-force performance
- Bike owned: VTR-250, VFR400RR,
Re: Cosworth 57mm Pistons HAVE ARRIVED
2 PMs received already. I will wait and see if there are any more over the next few days.
Due to the holidays, it is more difficult for me to reply. I will try to reply to all your questions as soon as possible.
Cheers and Happy Holidays everyone.
Mike Norman
G-Force Engine Development
Www.mngforce.com
Mike Norman
Www.mngforce.com
panteleimon
Pm'd
Interested.
How much is the estimate for pistons?
& What about the Carrillo A-Rods?
Cheers!
Interested.
Cheers!
g-force performance
Hang tight everyone. I am trying to get some response from my Piston vendors to see what the options are. Once i have that info, I will post in the "For Sale" section, and post a link here.
Cheers,
Mike Norman
Cheers,
Mike Norman
- Yakama
Any progress?
g-force performance
I currently have a request in to both Cosworth, and my new piston vendor for quotation. My new vendor will have a longer delivery time because they want to build true forging tooling. This will make the pistons even stronger, and less expensive. The new vendor has made me a few sample sets athat are absolutely outstanding Quality - as they should be. They are the same supplier that makes many OEM pistons that we are familar with, as well as the piston for some well established F-1 Engine builders.
The bigger delay is, I just found our that Yamaha has discontinued the rings I was using from the FZR400. This is really bad news as it means that I don't have a ring for the pistons at this time. I have asked the piston companies of they can make the rings as well. Also, I have something on the works for an alternate solution that I should know for sure about shortly.
So, hang tight. If the new vendor comes through, I can get these piston kits significantly down in price. We shall see.
Mike Norman
Mike Norman
- Yakama
Excellent thanks very much
- Variablevalves suck
Hi Mike I'm not buying pistons from you but can I ask a question on behalf of interested parties.
I read you are running nikasil liners on the 450 so are you having specific rings done for the nikasil, will people be ok in the standard steel bore.
g-force performance
We used NikaSil in the beginning. But, we have been using the original cast-iron for many years now. So, yes, everyone will be just fine.
Mike Norman
Mike Norman
crazyman
whats the Carrillo rods cost ? thanks
- Yakama
When I bought some for my nc29 they were about £1200
