Re: CBR400RR - Spring Service...
Posted: Thu Apr 02, 2009 11:37 am
Day 11
Took the bike for a little Dyno Run this morning... unfortunatly I don't have anything previously to go off, but I was a little disappointed :>
I'm not entirely sure what going on here... I'm now not sure whether my poor bike has been running restricted for the last 4 years or whether I have a bit of a problem. To be honest whilst I've had the Tank & Airbox off, I've never had the Carbs off, and from what I've read the restrictor washers are between the Carbs & the Engine... So I'm gonna be having a look at that at the first possible oppertunity.
Furthermore, my old man had this to say...
Day 12
Nothing done on the bike today, but I did take my daughter to get registered up at Southmead Hospital.
Besides, my MoT expired at midnight... lets pray for tomorrrow!
Meh... I guess I've still got a little work to be doing just yet!JET wrote: What exactly does this mean?
The power graph starts out as you would expect but at speed there is so much instrument/electronic noise present that all you can do is run an average line through it. (Smooth the graph). Anyway both runs look consistent – trouble is the power band should be measured at different RPM and MPH has little to do with it, gearing etc? I will try to find the website that explains why MPH is not the preferred method of testing output power.
When I [used to] check out the Aero Engines [in Rolls Royce] they are on a static/sea level test bed, nothing to do with how fast they are flying and our customers paying £XYZ a motor will only accept this method. I am of course referring to helicopter engines which run through a gearbox to the rotor head.
Also, there are no legends on that printout showing any scales regarding your Air/Fuel Mixture... so again, Whats does this all mean?
Day 12
