Stuck exup, grrrr!!
Phil Norton
Re: Stuck exup, grrrr!!
Post by Phil Norton »
sharpey wrote:on the r1 if it is fuel injected not sure if it would defo work but you could do like we used to have to do to suzuki's when fitting full race systems and do a pin out on the ecu so it doesnt register any of the exup, all ya do is get a wire diagram for the bike in question find out which pin of the ecu controls the exup and using the cprrect tool remove the pin from the connector, dont just cut it.
Cheers for the info Sharpey. Could come in useful down the line. I've got the 5JJ model from 2000, so no injection.
I'll have a look at that as an option if it goes again. Hopefully I should be good for a while, as I ended up with both a new bush on the valve and a new servo. The teeth on the servo had sheared off due to the effort required to try to move the exup. Wouldn't have been so bad if it hadn't happened in Andorra! Had to ride all the way through the Pyrenees and France with the engine delivering what felt like about 80 bhp.
Post by Evilchicken0 »
I thought if you took out the EXUP on an R1 you leave the servo in place otherwise it registers a fault code using the rev counter
Phil Norton
Evilchicken0 wrote:I thought if you took out the EXUP on an R1 you leave the servo in place otherwise it registers a fault code using the rev counter
That's true, but if the exup and servo valve both go again it may be worth my while trying to bypass the whole system.
Yes - what I mean is use a race exhaust or exhaust pipe section .... or scaffolding pole ... but leave the servo in place and connected. That way the CDI registers the servo and doesn't give a fault code.
Otherwise you could need a molesterd or race CDI
Phil Norton
Evilchicken0 wrote:Yes - what I mean is use a race exhaust or exhaust pipe section .... or scaffolding pole ... but leave the servo in place and connected. That way the CDI registers the servo and doesn't give a fault code.
Yep, thats what folks normally do with it.
Just wondering if in future Sharpey's GSXR solution may work on the R1. Something to look into.
