Wanted Signal Generator & Coil
Gavsta
Re: Wanted Signal Generator & Coil
Post by Gavsta »
I have a pair of working coils, HT leads and brand new plug caps if your interested.
Also a good known ECU.
Gavin.
Gazz
Post by Gazz »
Jamie, I was fortunate as a Dave from the forum was able to supply me one from a bandit, I haven't been offered another :( However Ebay Item 200307988289 looks promising, ask for a photo of the signal generator to compare.
Maybe somebody here will know if it will be the same.
Gazz
jamierooney
Post by jamierooney »
Thanks gazz. looking into it now. The resistance is reading 95 ohms on mine. Think I'll replace it nonetheless.
Gavsta
Post by Gavsta »
I also have the casing and pickup for a GK76a in my garage right now.
Ill do it for £20 + £6 delivery.
jamierooney
Sounds good Gavsta. Will you give me a resistance reading off the pickup wires so I know it'll be an improvement to my own?
A pic wud b nice :) if yu can.
J
Gavsta
Post by Gavsta »
Sure, Ill whip it off tomorrow night.
What points do you want me to take the readings off?
jamierooney
Its the resistance of the pickup coil itself..... The little magnet mounted to the inside of the casing. Its only got 2 wires coming off it (both secured in the one connector on the subframe). Will mail a pic on in the mornin of the location of the wire. Yu can actually test it without having the casing off, if the seat panel is already removed from the subframe.
J
jamierooney
Gazz wrote:Jamie, I was fortunate as a Dave from the forum was able to supply me one from a bandit, I haven't been offered another :( However Ebay Item 200307988289 looks promising, ask for a photo of the signal generator to compare.
Gazz
They wont give me a resistance reading off that, or send me any additional pics!! :x
jamierooney
jamierooney wrote:Its the resistance of the pickup coil itself..... The little magnet mounted to the inside of the casing. Its only got 2 wires coming off it (both secured in the one connector on the subframe). Will mail a pic on in the mornin of the location of the wire. Yu can actually test it without having the casing off, if the seat panel is already removed from the subframe.
J
Pic here of where to take that resistance reading.
Gavsta
Post by Gavsta »
As promised, here is a pic of mine - got it off tonight:
Can you point out the ends that need to have the meter put on please?
