Re: My rebuild at last!!
Posted: Wed May 07, 2008 4:40 pm
The banjo and line are as it was when I bought the shock I've never changed the position of it. The reservoir sits on the hanger side as it is on mine but it would also go the other side no problem.Kermit wrote:Posted before the 11 hr roll-back on the forum but it was along the lines of I have the same shock as you but mine being one that has been converted from use on an FZR400.
Now Im curious about the angle of the shock reservoirs banjo's and line as normally the reservoir would mount on the rhs of the subframe by the passenger rearset (I had to have mine swivelled in to the right when i had it serviced) but your line is pointing 90% to the left...is that on purpose? if is the reservoir going more of less in the normal place but on the other exhaust hanger side of the subframe?
