BACK FIRING AND BLACK SMOKE!! :(
Re: BACK FIRING AND BLACK SMOKE!! :(
Speedo is proabably a broken cable
- Bike owned: zx9r c1
this test does not need to be done with the lights on,especially full beam.sharpey wrote:just a note when you have the multi-meter and are doing the charging check at 5000rpm make sure u have the lights on and on main beam and as stated u shud get 13.5-15volts
as sharpey say's,and as i said in an earlier post you check the voltage @5000rpm......13.5-15volts
make a note of what the readings are and post them...then we can go from there
william
- w00dzy
http://400greybike.getmyip.com/newforum ... a&start=20" onclick="window.open(this.href);return false;
pics of the bike here..
he has not checked the bike yet as he has been busy today..
Hmmm ... 3en2 top fairing I think but it's got some white stuff on it
- w00dzy
its 12.42 starting.. then when reving at around 4-5k it goes down to 11.55 and slowly drops..
so would this mean it is the reg rec?
Sounds like the generator is not giving any juice for the regulator to rectify...
bad arrows..
bad arrows..
is the 12.42 volts before you start?w00dzy wrote:its 12.42 starting.. then when reving at around 4-5k it goes down to 11.55 and slowly drops..
what you need to do now is test the ac voltage output of the alternator now!!!!!
if this gives you good results then replace the reg/rec
my money is on a goosed reg/rec,more times than not a alternator on it's way out would still maybe give enough power to give you say......12.7-13volts @5000rpm.
to test the output of the alternator:find the connector that comes from the alternator and disconnect it.switch the multimeter to ac volts at least 100 range.start the bike and with it idling at 5000rpm test between two of the three white wires(yamaha i think)and take a note of the reading,then swap a probe over to another white wire and so on until you have taken three seperate readings.all readings should be at least 50 volts and all the same.
if this shows good results then i would suspect the reg/rec to be definately faulty.
william
- w00dzy
ok, we have now checked the wires coming from the alternator which is fine.. so it must be the reg/rec..
we finally managed to find the reg/rec which was underneath the fuel tank!! and was suprised to see it didnt have any fins on it? think they usually do to aid cooling..
does anyone have one they are willing to part with for little cash...?
thanks again for the help and advice..
- Motorcycle Solutions
the 3tj reg/rect and 1wg rect are flat without fins and also some model types of req/rect do hav fins on.. i may have a spare fin one lying around you can have just call it postage or a pint... will look through bike bits on sat/sunday
these reg rec usually depend on dissipating heat through a good earth.w00dzy wrote:we finally managed to find the reg/rec which was underneath the fuel tank!! and was suprised to see it didnt have any fins on it? think they usually do to aid cooling..
what results did you get from testing the alternator?did you test it?
i previously said that it sounds like the reg rec but it is always better to make sure as they are not cheap.
william
