NC30 battery keeps dying despite regular use
wullvfr
Bike owned: zx9r c1
Re: NC30 battery keeps dying despite regular use
Post by wullvfr »
next time after you have charged the battery test the charge rate @5000rpm........
it should be 13.5-15volts.
if the voltage actually drops then you probably have a dud reg/rec.
if however the charge rate is very low then test the output of the alternator as this is more than likely on its way out.
william
