1989 NC30 nut and bolt build
saltysealion
Re: 1989 NC30 nut and bolt build
Hi,
what did you use on your exhausts? Great result
pixelevolved
Great spotting mate!! Will get that flipped when I get to rear suspension. You are correct it was delivered that way haha. Even worse though, the nut holding the top of the shock was missing so the bolt was just sitting in there!richyrd5 wrote: Fri Jan 08, 2021 9:27 am Nice to see the pics!!!.. looking good fella,nice work.just one thing though,your dog bone is on wrong..it's upside down..curves should curve downwards...looks like it was delivered that way!!
pixelevolved
Cheers :) My process was wire wheel first, then various grades of (light) sanding, and finished with 2 passes of Autosol metal polish. Happy with the result for sure. Might go the full Tyga system in the future, but this will absolutely do for now.
richyrd5
Wow really!!!..make sure you check EVERYTHING underneath...good work fellapixelevolved wrote: Mon Feb 01, 2021 9:09 amGreat spotting mate!! Will get that flipped when I get to rear suspension. You are correct it was delivered that way haha. Even worse though, the nut holding the top of the shock was missing so the bolt was just sitting in there!richyrd5 wrote: Fri Jan 08, 2021 9:27 am Nice to see the pics!!!.. looking good fella,nice work.just one thing though,your dog bone is on wrong..it's upside down..curves should curve downwards...looks like it was delivered that way!!
wingy1962
Pix
What part of NZ are you In, Im in Christchurch with an '89 Seed NC30.
Regards,
Tony
Regards,
Tony
kiwimacchi
- One Hit Wonder
Hi Tony and pixelevolved, I'm following this with interest, have a '92 fully stripped, bodywork , plating done, rest blasted ready for painting and rebuilding. In chch too.
Foxy400
I'm eagerly but patiently awaiting the next instalment, I hope pixelevolved has got distracted.
