The ol' rec/reg problem (again).
Re: The ol' rec/reg problem (again).
good result
- Bike owned: Fizzy FS1E royal Enfield Grom
I’m in similar position I think my rectifier has gone as volts go up to 17v how much was new one also wear from and did you just plug in or change the plug also
Sorry for taking so long to respond to your post! I've been stuck in New Zealand for several weeks and only managed to get a flight home last Thursday. You've probably sorted this by now anyway but..
I got a replacement rec/reg from Graeme France. It's a heavy duty unit and better than the original. I can't remember what it cost I'm afraid but if you need one you've gotta pay up. I think I simply removed the old one and plugged in the replacement, without changing anything else.
If you want any more info let me know and I'll dig out my notes (yes, I write down everything that's done to my bikes because I can never remember what was done to which or when
..comes with age!).
Thanks foxy yes I will purchase a good new replacement then get it checked on multimeter again
Some more info in case you're interested. My replacement cost £92 direct from GF. It came with a new plug but as the original looked ok (to me) I didn't change it. Some time later I was zipping along the local bypass when the bike hit around 10,000 and started to splutter and struggle, eventually coming to a halt. After a brief rest it started and ran but had the same problem every time the revs built up. Long story short, after several calls to GF he took the bike away (while I was touring NZ). Amongst several things he did was to cut out the original rec/reg plug and fit a new one (if I'd known, I could have given him the new one that came in the box and saved myself £12), as well as the generator connection. It seems both had been damaged when the rec/reg died.
Had no problems since.
- Bike owned: NC29 CBR600F
Would it have been saved if the plug that came with the rectifier was changed at the same time or was the generator plug knackered by then also
Yup, should have changed the rec/reg plug at the same time. Whether the generator connection was damaged when the original R/R blew or later, when I ran the bike without swopping the R/R plug I don't know for sure, but I think it was the former. I should have checked both connections more thoroughly.
If Magg reads this he'll probably be able to shed some light.
