Page 2 of 2
Re: New arse end on my racer
Posted: Sun Jan 18, 2009 1:42 pm
by PARUS
Hi,
What kind of battery abd bettery box do you use? Can I have a picture or maybe dimessions.?
Cool bike...
Posted: Mon Jan 19, 2009 8:40 am
by greggo
Battery box is custom, cut and welded out of Aluminium plate.
I'll try and take a more detailed picture or two of how it fits plus write down the battery details.
Subframe welding is courtesy of Stimpy. Tops.
Posted: Sun Feb 08, 2009 8:24 am
by greggo
Battery is a YTB4L-BS It has less Amp Hours than stadard.
dimensions - 65 (w) x 110 (L) x 100 (Depth)
Pictures of battery box - bent alloy plate around the battery, left a couple of tabs to bolt it down - you can see at the petrol tank I had to place a spacer under it as it is a very tight fit in my subframe.
Side view - bolted on by the tabs at the front and back - notice the spacer under the front. I had to put it there as my new subframe is a very tight fit!
Top down view, batery fits like a glove. I have holdes drilled in the side, and one in the bottom, to help when removing the battery.
