Can anyone suggest a good starting point for setting carbs?
ArronA
Re: Can anyone suggest a good starting point for setting car
It's the same diagram as the one in the rrsp manual, it shows you 2 washer / spacer looking things one is plastic and the other is metal but it doesn't show or tell you which order they go in
I'll try to have a look today.
ArronA
Brilliant that would be greatly appreciated! also if you read this prior to looking could i have your needle clip position please!Evilchicken0 wrote:I'll try to have a look today.
ArronA
Any luck ?Evilchicken0 wrote:I'll try to have a look today.
Robotnik
- Bike owned: 2x3tj xs650
ArronA
I've looked at that mate several times, you would think they would number and name every single piece so that you would know what order to put everything back in
Robotnik
Take a close look at the two washers, one is thicker than the other, one might be a plastic spacer.
Do you have two washers / spacers, one thicker than the other?
Neil
Neil
This was from my spares set
Robotnik
That makes things clear, I've added labels to the original image.
Back to fitting my rear wheel...
ArronA
Oooh that is interesting, the plastic washer is sandwiched between 2 metal ones, i have loads of spare carbs bit's and pieces for the 3tj so I'll hunt out some more washers and try it, it's strange because the diagram only shows one of eachEvilchicken0 wrote:This was from my spares set
