NC 23 Starting problems
wullvfr
- Bike owned: zx9r c1
Re: NC 23 Starting problems
luke2405 wrote:Checked that there is voltage to it which there was
i think if he is getting voltage at the fuel pump then the fuel pump relay must be working correctly......kiwi racer wrote:Another thing to try is to check the fuel pump relay
william
kiwi racer
- Bike owned: CBRs
Negative .... power at the pump does in no way mean the relay is switching correctly to purge the pump. EG; you can have power at the pump but no switching ignition power from the relay to allow the pump to actually pump.wullvfr wrote:luke2405 wrote:Checked that there is voltage to it which there wasi think if he is getting voltage at the fuel pump then the fuel pump relay must be working correctly......kiwi racer wrote:Another thing to try is to check the fuel pump relay
william
There is a test procceedure for the relay but no repair advice at all (its not servicable) .
The pump has a test procceedure for delivery volume etc and a repair advice.
If there is power to the correct wire when cranking then you are correct but just static power to the pump is not enough.
luke2405
had the pump changed and its running fine now feels a little more responsive than before so maybe it was going for a while
