Charging problem
manicguitarist
- Bike owned: RVF400 (NC35)
Re: Charging problem
Use an in-line fuse.demerdzhiev wrote:everything is clear except the part with the fuse, i am an electricity cripple so pls help with the fuse :D
I'd suggest that if you don't know about this - that you get someone else to do it.
M
demerdzhiev
- Bike owned: NC21
got it. thank you
- Bike owned: VFR400
The fuse is simply inserted between the +ve output of the rect/reg and the +ve terminal of the battery.
marti
Don't forget to check and clean/replace connector from alternator.
This can cause all sorts of problems
