Page 2 of 4
Re: Nc24
Posted: Sun Feb 28, 2016 3:14 am
dudleygareth wrote:
thats fucked, there are no fins left on it, they have rusted off.
it should look like this.
I have come across this before on neglected nc24s.
You need a new wateprump (nc30 one will fit if i remember rightly)
remove stand and waterpump hoses and flush with hosepipe until water is clea.. do same for radiator.. flush it both ways.
there are two drainbolts under the exhust downpipes.. remove them to aid flushing.
replace thermostat if junked.
replace rad-cap too
should run very cold after that and fan shouldnt come on until nearly into the red, which on an nc24 is hardly ever
Re: Nc24
Posted: Sun Feb 28, 2016 3:15 am
richyrd5 wrote:I've seen worse but looks ok..best to just spin it over on starter quickly to see if it spins..you wouldn't be able to turn it by hand anyway...check hoses and flush them through until water is clear
see above... that waterpump is toast.
also its connected to the oilpump shaft so wont turn unless the motor is turning.
pps.. when you remove the waterpump to replace it, be aware all the engine oil will come out
Re: Nc24
Posted: Sun Feb 28, 2016 3:53 am
by richyrd5
Lol..only just looked at this on full screen..was on phone screen and wow!!.yup that pump is shot!!!..apologies to op for that!..sheepish grin!!
Re: Nc24
Posted: Sun Feb 28, 2016 11:10 am
by hunter
Have you put the gear linkage back to it's correct position.
Re: Nc24
Posted: Sun Feb 28, 2016 3:00 pm
by dudleygareth
Hi guys I've got that all sorted tx.I no sit with a problem that my gears are upside down.What could I have done wrong?higher gears is down and lower gears is up.please assist
Re: Nc24
by dudleygareth
Tx for all yours guys guidance much appreciated
Re: Nc24
Posted: Sun Feb 28, 2016 10:29 pm
by hunter
The lever on the engine gear shaft is the wrong way up.
Re: Nc24
Posted: Mon Feb 29, 2016 5:09 pm
by dudleygareth
Tx guys all sorted now just too get new waterpump but I have too import coz I can't get one in South Africa do u guys no what it cost in the uk
Re: Nc24
Posted: Tue Mar 01, 2016 9:18 am
dudleygareth wrote:Tx guys all sorted now just too get new waterpump but I have too import coz I can't get one in South Africa do u guys no what it cost in the uk
waterpump long discontinueud, new price was aroung 175gbp.
there are aftermaket electrical pumps you could wire into the bike that you could probabyl source locally.
the only option is a second-hand one, which is no problem to use as long as you source one that has been used with correct coolant and not rusted up with normal water
Re: Nc24
Posted: Fri Mar 11, 2016 5:39 pm
by chownsy
dudleygareth wrote:
That is nackered, there are no fins on the water pump. I will show you a photo of mine if you like to compare.
Also sludge tends to sit in the V part of the block, I know as I just stripped my engine and 1 jet wash and 1 industrial ultrasonic clean later and its still rusty but the sludge has gone.
