Nc24
Re: Nc24
thats fucked, there are no fins left on it, they have rusted off.dudleygareth wrote:
it should look like this.
I have come across this before on neglected nc24s.
You need a new wateprump (nc30 one will fit if i remember rightly)
remove stand and waterpump hoses and flush with hosepipe until water is clea.. do same for radiator.. flush it both ways.
there are two drainbolts under the exhust downpipes.. remove them to aid flushing.
replace thermostat if junked.
replace rad-cap too
should run very cold after that and fan shouldnt come on until nearly into the red, which on an nc24 is hardly ever
Re: Nc24
see above... that waterpump is toast.richyrd5 wrote:I've seen worse but looks ok..best to just spin it over on starter quickly to see if it spins..you wouldn't be able to turn it by hand anyway...check hoses and flush them through until water is clear
also its connected to the oilpump shaft so wont turn unless the motor is turning.
pps.. when you remove the waterpump to replace it, be aware all the engine oil will come out
dudleygareth
Re: Nc24
Hi guys I've got that all sorted tx.I no sit with a problem that my gears are upside down.What could I have done wrong?higher gears is down and lower gears is up.please assist
dudleygareth
Re: Nc24
Tx for all yours guys guidance much appreciated
dudleygareth
Re: Nc24
Tx guys all sorted now just too get new waterpump but I have too import coz I can't get one in South Africa do u guys no what it cost in the uk
Re: Nc24
waterpump long discontinueud, new price was aroung 175gbp.dudleygareth wrote:Tx guys all sorted now just too get new waterpump but I have too import coz I can't get one in South Africa do u guys no what it cost in the uk
there are aftermaket electrical pumps you could wire into the bike that you could probabyl source locally.
the only option is a second-hand one, which is no problem to use as long as you source one that has been used with correct coolant and not rusted up with normal water
chownsy
- Bike owned: KS125, ER5,VFR400 NC24
Re: Nc24
That is nackered, there are no fins on the water pump. I will show you a photo of mine if you like to compare.dudleygareth wrote:
Also sludge tends to sit in the V part of the block, I know as I just stripped my engine and 1 jet wash and 1 industrial ultrasonic clean later and its still rusty but the sludge has gone.
