Project "Casualty"
Zippy
Re: Project "Casualty"
Post by Zippy »
They need to be going round Snetterton in October as well.
CRM
Admin NWAA
Admin NWAA
Post by CRM »
Ooh ooh - it's starting to take shape.
wheels are perfect, i love the gold combo. may be a bit old school but then so am i and so is the bike.
big disc and adapter is going to stand this on it's nose.
routing the hose on the outside is safer with the OE hose, i may look at aftermarket if i can route internally neater and safer without any risk of rub
marcus57
Post by marcus57 »
That looks mean , i keep considering a sm of some sort for road use
CRM
Admin NWAA
Admin NWAA
Post by CRM »
crm takes some beating, a good balance of weight, reliability and performance
but needs to be a AR to look good and good AR's aint cheap, then there is the wheels, brakes etc
you have seen my AR on track, it surprises a few folk
CRM
Admin NWAA
Admin NWAA
Post by CRM »
Rear wheel on
Side stand on (found a used billet one on ebay for £60 and fits perfectly and clears out of the way perfectly too - best £60 spent yet IMO)
Just need to grease the seals accordingly, final fit up, fit new o-ring chain, connect speedo to the capacitor thing, fit the enduro type rear mudgaurd / numberplate holder.
vic-vtrvfr
Bike owned: NC30 x4, VTR1000 Firestorm
Post by vic-vtrvfr »
That looks amazing - great taste Sir, look forward to updates and hopefully seeing it tear around Anglesey next year!
CRM
Admin NWAA
Admin NWAA
Post by CRM »
Well a month on much has changed.
The bike was completed and had quite a bit of time being setup by Ian @ Viper racing who specializes in carts that use the CR250
It was evident all was not well on the first few dyno runs and the power was low 40's and with a horrible tail at the end of the rev range that went not only seriously lean, but the ignition curve advanced early on the original ECU in an effort to curb over revving.
clearly this has quite a negative effect on the engine by firing the ignition before TDC thus putting negative forces on the crank and engine.
This was not the only issue. the garage i bought it from had fitted a new original piston as part of the deal - sadly the muppets fitted a 02 - 04 piston that is flat domed and not the correct domed 05 - 07 item. as such i was down a bit on compression and CC so that needed sorting.
So now with a new piston, custom ECU and maps and PV set correctly the beast was making high 40's bhp and a nice healthy curve.
running the 14 / 38 gearing with 17" wheels it was topping out at an indicated 106 mph @ 10k rpm, so with some minor limiting and jetted to suit it was ready for it's first outing.
So on the 20th i rocked up to RAF Valley ready to enjoy this and give it it's first maiden run.
The first session was very nervous, brand new tyres, new bike, new brakes and running the new piston in.
Very quickly i managed to pop a fork seal on the brakes that then dumped all its oil over the front disk making stopping quite interesting. however i carried on and really enjoyed the bike and even managed to pass a few sportsbikes in the corners.
the grunt coming out of corners was impressive i have to say, faster than the CRM and way way lighter to ride with much firmer suspension.
Was i any quicker on this than the CRM ? possibly not no, tyres, brakes engine i suspect had i have been on the CRM i would have been quicker.
Come the second session, a quick top up of fuel (Christ it likes a drink of the old 32:1 mixture this thing) and out i go
a warm up lap then i was off like a greyhound out of a trap and the bike was flying. quickly started to catch up the back end of the group and the bike was effortless to scythe around big cumbersome heavy fast bikes in the slower corners but come to the long straight it was on the limited and topped out doing over a ton at less than third of the way which was frustrating.
in my mechanically sympathetic mind i thought it best to back off a bit on the long straight by running at part throttle - big mistake.
now when i say big mistake i mean - like really big, i would have been better simply shutting off the throttle or keeping it pinned and not going half way house lol
as such the inevitable happened - i seized it. I felt it start to slow so quickly whipped the clutch in where it stopped dead. i coast to a slower pace and try to free it with a bump, much to my surprise it starts and runs fine so i nurse it back to the pits where i sit and sulk for a bit.
As such it was loaded back in the van and i borrowed Paul Tye's (tye noodles) well sorted NC30 for a session before an early bath.
CRM
Admin NWAA
Admin NWAA
Post by CRM »
So the next day i had decided i wasnt going to bother returning to Valley but after waking at 6am i thought better of it and leapt out of bed to quickly load the van with a working bike and make the most of the day that was paid for.
So after a quick mental descision to take the trusty RVF and after a quick argument with myself i ended up loading the RG500 gamma up for a days thrashing because of the following reasons - it had more petrol in it !!
And boy i was glad i did, i had more fun wobbling around nervously on skinny tyres and weak brakes having epic fun - sorry but the RVF as good as it is, it fails to deliver the same smile and cheezy grin at the end of each session.
CRM
Admin NWAA
Admin NWAA
Post by CRM »
So back to the CR250
Well after a strip of the top end by Ian, he confirmed a pretty unlucky seziure.
by unlucky he said another hour on that piston it probably wouldnt have seized and it was only because it was still a little tight and the gasses couldnt escape quick enough at high RPM coupled with my part throttle actions.
So with no damage done a new piston will be fitted, up one size on the main to cater for reliability over outright bhp, a new set of genuine honda forks seals and she will be good to go on the next track day. . . . . .
However . . . . .
My love for the CR has grown and as such i am finding myself not happy with the odd mark here, the odd scratch there and it may well be the last of the classic 2 stroke CR's being an 07, but it's still a motocross bike that's been "used"
So after a couple of inquiries idle curiosity took hold and i wondered if there were any new old stock CR's sat in crates somewhere like a fairy tale that i could buy and have a brand new bike.
Well funnily enough i found the next best thing - i managed to secure a 07 CR250 that has been used once.
yes once, and by once i mean - filled with fuel, started and run up a private dirt track when new then parked for 2 years after cleaning before being bought by someone else as an investment who then cleaned it to death and then parked it in a spare bedroom in parts for the next few years.
So it would appear i have now purchased this other bike and it really is as new, original tyres are still un worn, one small mark on the swing arm, seat cover replaced with a pattern item after something fell on the seat and put a hole in the cover, but more importantly the bike, engine, frame and all parts are new and un faded or corroded or even aged. - this is the bike for me.
It is easy to keep a new bike looking new, but much harder to get an old bike looking back like new.
So the plan is as follows
Switch all the nice SM parts over to this new bike
put the original bike back to exactly the same spec as i bought it (with new piston, jetted and setup correctly and new fork seals) and sell it on next year as a road registered bike - i can't lose money on this and it will sell easily.
Road register the new bike - this could be a painful process but worth it.
use the new bike for short twisty circuits next year and use the freshly rebuilt CRM for anything with a longer straight involved.
Variablevalves suck
Post by Variablevalves suck »
Haha, are these things growing on trees?
That part throttle is a kill on a t2, especially if you backed it off as apposed to not giving it all the beans.
Do you think it will take a slightly higher gearing to stop the top out, if it still nips up with the higher jetting you could up the oil ratio a little.
