NC24 Rear Shock, terrible idea??
clubber122
- Bike owned: VFR400 NC24
Re: NC24 Rear Shock, terrible idea??
Neo is it worth me putting an NC30 shock on to Jack it up a little?
it wont fit, too long.clubber122 wrote:Neo is it worth me putting an NC30 shock on to Jack it up a little?
clubber122
I thought I could squeeze it in and it would Jack it up?Neosophist wrote:it wont fit, too long.clubber122 wrote:Neo is it worth me putting an NC30 shock on to Jack it up a little?
never tried it, but its much longer as stock, i think itd ruin thebike if you could even get it in there..clubber122 wrote:I thought I could squeeze it in and it would Jack it up?Neosophist wrote:it wont fit, too long.clubber122 wrote:Neo is it worth me putting an NC30 shock on to Jack it up a little?
clubber122
I read on here it's only 20mm difference? Is that incorrect?
its 25mm i think, 280 vs 305mm so about 1inch.
Jacking the rear up will cause the front to steer quicker but sacrifice some straight line stability.
Due to the already 18/16" setup with wheels the NC24 already steers pretty quick.
Nothing to stop you trying it and see if it fits / how you get on.
clubber122
Thanks Neo I wouldn't want to try it unless I was pretty sure it would work well
