Re: NC21 with NC24 carbs
Posted: Fri Sep 12, 2014 6:11 pm
I cant see what airbox you are trying to use as there are no picture.spikenipple wrote:Further to the coil fitting issue, I can't seem to get the airbox base back on with the coils fitted. There is a large tray protruding from in front of the front two airbox>carb screws that goes precisely where the coils sit. Do I have the wrong airbox?
The NC21/NC24 aircleaner is interchangable though.
http://images.cmsnl.com/img/partslists/ ... 9_b7d2.gif
you can see a picture of it here.
If your carbs are fouling the coils then there is obviosuly something wrong with the fitting of the carbs, which will probably also stop the airbox fitting.
did you solve the issue with the coils yet? fix the airleak symptions? you shouldnt ride it with possible airleak, espeically on a high revving v4 you risk burning the valves out.
