Re: Just Got My RVF400 Dyno Tuned
Posted: Tue Nov 19, 2013 10:50 am
Very likely you have a air leak then
http://www.400greybike.com/forum/
Its running lean, usually caused by an air-leak somewhere... most likely knackered carb rubbers / poorly fited carbs / carb clamps or vaccum line / vaccume take off port opened up.wogstaa wrote:The intake is stock too other than me removing the foam on the snout because it was all dry and breaking up, I can't imagine that would make much, if any difference at all. But then, I don't know these bikes very well... yet
They didn't seem concerned about the jet size though, so I'm confident it's all good. The fuel economy will probably take a massive drop though but that doesn't concern me.
I did notice the idle hangs up a bit though when I come to a stop.
Yes, in my experience if the carbs are seated properly then hanging revs is usually pilot screw not set correctly.wogstaa wrote:I'm just suspecting the idle mix might be set a lean, I had it a tiny bit richer than stock before I took it in and it was fine.
That, or carbs are way out of balance. But I'd assume it's pilot screws or just a misadjusted idle as they're the only two things they should've touched and there's no air leaks that I could find.Cammo wrote:Yes, in my experience if the carbs are seated properly then hanging revs is usually pilot screw not set correctly.wogstaa wrote:I'm just suspecting the idle mix might be set a lean, I had it a tiny bit richer than stock before I took it in and it was fine.
Not at all.wogstaa wrote:That, or carbs are way out of balance. But I'd assume it's pilot screws or just a misadjusted idle as they're the only two things they should've touched and there's no air leaks that I could find.Cammo wrote:Yes, in my experience if the carbs are seated properly then hanging revs is usually pilot screw not set correctly.wogstaa wrote:I'm just suspecting the idle mix might be set a lean, I had it a tiny bit richer than stock before I took it in and it was fine.
EDIT:
I am running 95 octane fuel if that has anything to do with the jetting, I can never find a definitive answer on whether using higher octane fuel will affect jetting on carbs.
wogstaa wrote:Hey all,
I just got my bike back from RB Racing.
Thought I'd post up the graphs since I'm no expert on these things to see what you all think... It ended up requiring size 125 main jets, to my surprise.
TSR Titanium system is the only mod performance mod.
[url=http://imageshack.us/photo/my-images/12/ym3r.jpg/][img]
