intermittent running issue
stedo
- Bike owned: nc29,nc35x3,600rr,SP1
Re: intermittent running issue
Just replied this but god knows where it went.
Check the spade connectors on the front coil, I had a similar problem on a track day a couple of years ago. Wire into the connector had corroded causing intermittent fault. Another way of checking is have the bike running and see how hot the down pipes are getting.
Hope it helps
Hope it helps
