30 / 35 riders, lack of cush-drive question.
Re: 30 / 35 riders, lack of cush-drive question.
VERY doubtful!Neosophist wrote: VFR400R(NC24) Overview : Change rear swing arm to PRO-ARM.
(Apr,'86) Max. H.P. : 59PS / 12500rpm
Tolque : 4.0kg-m / 10000rpm
Size : 2010mm(D) x 690mm(W) x 1125mm(H)
Wheelbase : 1375mm
Dry weight : 164kg
Front wheel : 100/90-16 54H
Rear wheel : 130/70-18 63H
Price : 679,000yen ($7,988)
VFR400R(NC30) Overview : The first model of NC30. All parts are
(Dec,'89) renew. With 360 degrees crank.
Size : 1985mm(D) x 705mm(W) x 1075mm(H)
Wheelbase : 1345mm
Dry weight : 182kg
Front wheel : 120/60R-17 54H
Rear wheel : 150/60R-18 67H
Price : 695,000yen ($8,176)
VFR400R(NC30) Overview : Suspention changed(front/rear)
( ,'91) Max. H.P. : 59PS / 12500rpm
Wheelbase : 1345mm
Dry weight : 185kg
Price : 719,000yen ($8,459)
20kg lighter!!
Don't believe everything you read...
Hehe I know..
I have the owners manual here it lists the Kerb weight as 183kg
Acutally having read that again...
車両é‡é‡ãƒ»ãƒ»ãƒ»ãƒ»ãƒ»ãƒ»183(kg) [Kerb Weight]
乾燥é‡é‡ãƒ»ãƒ»ãƒ»ãƒ»ãƒ»ãƒ»164(kg) [Dry Weight]
It is a proper slipper design of clutch that is pretty efficient too. It abuses half the clutch pack though! The current retrofittable ramp type slippers are just trendy ..lolStickshift wrote:It does use one in the clutch function.fastdruid wrote:A sprag clutch is a one way clutch typically used for the starter. I'm pretty sure the NC30/35 doesn't have one in any other function.Stickshift wrote:The nc30/35 has a sprague clutch that acts as a kind of slipper clutch, this may reduce the wear of not having a cush drive. Does the 24 have this?
Not typically a true slipper clutch by todays standards, but like Jon said it eases pressure on teh clutch under heavy engine braking.
