Page 2 of 2
Re: Rev counter still not working.
Posted: Fri Aug 30, 2013 6:27 pm
by wambam87
After some help from my dad, I have 13v ish at my tachometer, and 0.5 volts from the signle wire. Are these values enough? Or is my new tacho dead too?
Posted: Fri Aug 30, 2013 11:41 pm
by Cammo
Are you sure you have the correct tacho for the bike? Rvf and vfr are not interchangeable.
On the rvf tacho 0 rpm is in the 6 o'clock position, on VFR tacho it's around the 4 o'clock position.
Posted: Fri Aug 30, 2013 11:57 pm
by magg
12 volts
Posted: Sat Aug 31, 2013 3:57 am
Cammo wrote:Are you sure you have the correct tacho for the bike? Rvf and vfr are not interchangeable.
This is important.
You cant use the wrong tacho :)
Posted: Sat Aug 31, 2013 9:14 am
by wambam87
Have checked and there exactly the same. There's a "working" tachometer on ebay at the moment, going to see if I can nab it.
Posted: Sun Sep 01, 2013 1:49 am
by Cammo
Do you have the earth wire screwed onto the back of the tacho?
