Hi guys me again lol exhaust studs and nuts ?
Re: Hi guys me again lol exhaust studs and nuts ?
No ... it comes from this post ... Willandrip is saying the nuts are cheaper if you buy these and throw away the studs. You'd still need to get some M6 studs but I don't know the length, you'll need to measure yours.willandrip wrote:A search returned this item in 1.26 seconds;
http://www.ebay.co.uk/itm/Scooter-Moped ... 1270wt_992
Use the nuts/discard the studs.
EDIT ;The link is included as these nuts are very similar to the original .
willandrip
NO Chris; that link is only for the nuts that come with the studs.
The nuts are very similar in shape and size to the Yam ones but much cheaper.
The studs are no use to you.
They do not list just the nuts.
The unthreaded portion on any stud is usually just to help prevent corrosion build up or weakness of the stud where the flange fits.It also helps with fitting the stud.
Edit;posted at same time as Boris.
chris6409
Lol cheers fellas
