Page 2 of 2
Re: HELP - Knocking noise after valve clearances checked
Posted: Fri Aug 02, 2013 11:18 am
by magg
"IN" does go on the carby side and the gasket is also marked with "IN" and an arrow. You say the noise is apparent with the covers nipped down, is this both covers?
Posted: Fri Aug 02, 2013 11:28 am
the gasket might be getting squished out the way a bit?
Posted: Fri Aug 02, 2013 12:30 pm
by Giffin101
I think its sorted, added a liberal coating of silicone gasket to the front cover and no more noise.
I think the gasket has aged and was letting the parts touch?
It is running sweet, for now..
Posted: Thu Aug 22, 2013 9:15 am
by Giffin101
Well bloody hell its started again once the engine has warmed up. It is pulling strong especially since I replaced the rubber mat in front of the carbs.
I know its something to do with the front rocker cover but am stumped.
Posted: Thu Aug 22, 2013 9:41 am
by Drunkn Munky
Wild stab in the dark but could the head get starved of oil if the pick up is blocked or dislodged somehow?
Posted: Thu Aug 22, 2013 9:43 am
by hunter
Sounds like the old gaskets have compressed,
Take cover off,Remove old gasket, clean gasket and cover, when dry put a bead of silicone in the grove of the cover,
Place the gasket on cover, then turn cover over and place on a flat surface.Leave it for an hour or two then refit.
Posted: Thu Aug 22, 2013 9:53 am
by Giffin101
Drunkard, will look in to that.
Hunter, thats what I did previously, its odd it has not worked long term, I think a new gasket is in order, anyone have one?
Posted: Sat Aug 24, 2013 7:57 am
by Giffin101
Gasket ordered from Rick Oliver.
