Bahh, electrics.
pearson*
- Bike owned: FZR400RR
Re: Bahh, electrics.
Just looking into reg/recs but i've got a quick question for anyone who understands the yams part codes.
Mine has 47X-A1 SH569-12
The ones i've seen all have 3TJ-01 SH569-12 stamped on them.
Some of them are 47X-A0, 47X-A2 and 42X-A2.
Question is, do the first 5 digits of the part code matter in any way or is it only the SH569-12 part of the code that defines the item?
Cheers.
Cheers.
willandrip
47X-A1 SH569-12
47X -A1 =Fitment type and terminal configuration (This is what is known as the "Mars Bar " type fitted originally to loads of 80's/90's Yams.See example)
SH569-12 = SH569 (shunt type rectifier/regulator) -12 =12volt.
Pattern ones are about £22;these have fins on them to aid cooling (heat sink)
They earth via a harness tag through a fixing bolt (make sure its clean)
http://www.ebay.co.uk/itm/YAMAHA-TWFZR4 ... 2223wt_755
I believe in your case the terminal configuration is correct (4 male spades.). (3tj owners will confirm )
http://www.ebay.co.uk/itm/1990-Yamaha-F ... 2054wt_758
The above is essentially the same item.
pearson*
Cheers for clarifying, mines looks exactly the same (connection) but without the heatsink pattern on the top. It's simply just a flat metal case which kinda threw me a little when looking through various plugs.willandrip wrote: Pattern ones are about £22;these have fins on them to aid cooling (heat sink)
Thanks again.
Sounds like a 1WG reg rec but it could be from any bike, omebody probably replaced it at some time.
Fit a 3TJ one and it should be fine.
willandrip
Boris can you put up a link for what an actual 3Tj one looks like please;so many indescrepancies on sellers descriptions.
I take it they are 4 pin though ?
willandrip
willandrip
Coincidence or what;just picked up a TDM 850 mk1 today ;and low and behold it has a reg/rec same as the one in the links, fitted.
Strange location though;outside of frame at very front by tank mount.
