Flat tyre!
- benny
Re: Flat tyre!
By hand I meant with his fingers! I do plan to use a wrench or won't this work?
DM104 for the road race team.
Re: Flat tyre!
if you are feeling strong.. Have you ever had the wheel off?
I use a socket and a foot long breaker bar.
Re: Flat tyre!
If you've never had it off loosen the nut before you put it on a paddock stand, chances are its done up FT so having the wheel on the deck will help.
- benny
Re: Flat tyre!
Just on my way to get a torque wrench, rated past 120nm so it should be able to undo it if its big enough? I don't really know but I need it all sorted today as I need the bike tomorrow morning :s
- jim157
Re: Flat tyre!
Dont use a torque wrench to undo bolts, get yourself a breaker bar.
AUTOEXEC.TWAT
- benny
Re: Flat tyre!
On my way to the ironmongery so will sort that out too
Re: Flat tyre!
Aye, you cannot undo things with torque wrenches..they get broken
- benny
Re: Flat tyre!
Got a breaker bar too then specifically "at least a foot long"CMSMJ1 wrote:Aye, you cannot undo things with torque wrenches..they get broken
Edit to add: it's 18"
- benny
Re: Flat tyre!
Update: breaker bar got the wheel off quite easily, just having lunch then onto the tyre place James recommended already phoned to check they have it in stock
- jim157
Re: Flat tyre!
benny wrote:Got a breaker bar too then specifically "at least a foot long"CMSMJ1 wrote:Aye, you cannot undo things with torque wrenches..they get broken
Good stuff, they're an essential tool imo.
AUTOEXEC.TWAT
