Re: ZXR 750 H1 in Green White and Blue
Posted: Sun Jul 07, 2013 11:19 pm
The top yoke was plain nasty, years of keys marking it and some surface corrosion too. The stock finish I think is like it’s been held on a belt sander, then anodised and then possibly lacquered. I cleaned it up with celly thinners, cleaned it up with a scotchbrite pad, cleaned again with thinners and then a coat of celly lacquer. Then once dry polished up with mini DA and compounding mop with some cutting paste
The finished thing looks much better. Which now reminds me to do the one on the KR1-S, which is similar and the NC30 one needs to be done in Satin black too, missing paint where I fetched the carbon yoke cover off.
Here’s the mini DA, really handy, came in a kit with 2” and 3” [50 and 75mm] pads and sanding discs. But fit a sponge pad and it’s ideal for polishing or cutting too. Use a reasonable amount of air, my compressor will keep up but runs pretty much all the time. Similar item http://www.ebay.co.uk/itm/3-75mm-Air-Mi ... 4d0dfda26d
Talking about tools I had to buy a few tools for working on the 851 recently and bought them from http://www.thetoolacademy.com/ the prices are very good, much cheaper than ebay, but you get stung on the £10 shipping charge, so there’s an incentive to buy more! I bought one of these cable oilers, never had one before but very impressed with it http://www.thetoolacademy.com/list_prod ... archtype=0
I got stuck in and refitted the oil cooler, oil filter and pipes. Interestingly the H1 ZXR uses a remote filter housing, which is dead easy to get to, later models were in the sump. Filter is a stock item
Code: Select all
, £6 from Halfords, not as cheap with a trade card as I thought, they’re only £5 online inc delivery.
[url=http://s188.photobucket.com/user/oilphiluk/media/Kawasaki%20ZXR750H1/IMG_2121_zps34efb9fb.jpg.html][img]http://i188.photobucket.com/albums/z143/oilphiluk/Kawasaki%20ZXR750H1/IMG_2121_zps34efb9fb.jpg[/img][/url]
Filled the motor with some 10W40 I got from Hein-Gericke in their big oil sale last year, before they went into liquidation.
I considered dropping the stock exhaust but in the end didn’t get any further than checking all the nuts were loose/not seized. Whilst the top yoke and forks were off I dropped the steerer stem/bottom yoke out and checked the bearings, they were perfectly good so some new grease and back in.
Radiator and associated bits all got refitted. Forks back in. I removed the discs from the front wheel and clean them and the wheel with wheel acid, prior to using gunk and then soapy water. Followed by some adhesive remover on spots of the old wheel weights. They came up great, really nice. Was impressed, the stock Kawasaki wheels of the period seem to be almost porous and seem to ‘absorb’ dirt and brake dust.
[url=http://s188.photobucket.com/user/oilphiluk/media/Kawasaki%20ZXR750H1/IMG_2141_zps692fdfe0.jpg.html][img]http://i188.photobucket.com/albums/z143/oilphiluk/Kawasaki%20ZXR750H1/IMG_2141_zps692fdfe0.jpg[/img][/url] [url=http://s188.photobucket.com/user/oilphiluk/media/Kawasaki%20ZXR750H1/IMG_2140_zps1597c29d.jpg.html][img]http://i188.photobucket.com/albums/z143/oilphiluk/Kawasaki%20ZXR750H1/IMG_2140_zps1597c29d.jpg[/img][/url]
Carbs were off. I admit to being one of those that didn’t know that Japanese bikes used a different type of crosshead screw, the JIS. So I’d ordered on from http://www.modelsport.co.uk/index.php?s ... ring=74006 as per the recent thread
The MOT history basically shows the bike has done less than 200 miles a year since 2005. So I was expecting the carbs to be in a mess. I don’t think they’d ever been apart, they were 98% mint inside! I didn’t even bother putting them through the ultrasonic tank, just cleaned all the road grime off the outside in the parts washer. Float height were all spot on at 13mm.
Whilst the carbs were off I pulled the plugs out, basically new. Then rocker cover off. Cam chain and tensioner looked good, cams were also mint, no scoring and to my real surprise the valves were all in tolerance for clearance. Unusual for an old bike, and nice because I think it’s cams out to do them.
I’d ordered a remote/ auxiliary tank for balancing the carbs but it still hasn’t arrived. I hooked the balance gauges up and used the same old gearbox oil bottle I’ve always used. There’s a ‘web’ of lockwire around it to allow it to be hung upside down. Just like the rest of the engine the balance was pretty good. NC30 owners please don’t cry, if only balancing carbs on an NC was this easy, look where the adjusters are!
[url=http://s188.photobucket.com/user/oilphiluk/media/Kawasaki%20ZXR750H1/IMG_2123_zpsfbba2d08.jpg.html][img]http://i188.photobucket.com/albums/z143/oilphiluk/Kawasaki%20ZXR750H1/IMG_2123_zpsfbba2d08.jpg[/img][/url] [url=http://s188.photobucket.com/user/oilphiluk/media/Kawasaki%20ZXR750H1/IMG_2122_zps3b739368.jpg.html][img]http://i188.photobucket.com/albums/z143/oilphiluk/Kawasaki%20ZXR750H1/IMG_2122_zps3b739368.jpg[/img][/url]
I built the calipers back up. But how I lost one dust seal I don’t know. Just as well I only needed one, it cost about £5 from Kawasaki, there’s 10 piston seals and 10 dust seals in the 3 calipers. Easy to see how you could spend £100 on seals. Luckily the original seals and pistons were nigh on mint so all got reused. The leaking brake lines that were the cause of the strip and brake fluid everywhere were fine when assembled properly with copper washers. In fact at one point where there two banjo’s on the same bolt there hadn’t been a washer between them. I’m sure this was the main cause of fluid leak, together with loose bolts!
[url=http://s188.photobucket.com/user/oilphiluk/media/Kawasaki%20ZXR750H1/IMG_2120_zps9a51f374.jpg.html][img]http://i188.photobucket.com/albums/z143/oilphiluk/Kawasaki%20ZXR750H1/IMG_2120_zps9a51f374.jpg[/img][/url] [url=http://s188.photobucket.com/user/oilphiluk/media/Kawasaki%20ZXR750H1/IMG_2119_zps853a7d35.jpg.html][img]http://i188.photobucket.com/albums/z143/oilphiluk/Kawasaki%20ZXR750H1/IMG_2119_zps853a7d35.jpg[/img][/url]
