Page 2 of 2
Re: NC30 HRC camshaft copies
Posted: Mon Mar 18, 2013 10:01 am
by hunter
Timon wrote:Drunkn Munky wrote:Pretty much sod all unless you have the rest if the engine kit parts
As Tony says HRC rods and pistons are needed to go with the cams. Unless you want to start machining deeper valve pockets on stock piston crowns
Would love to get involved with this but its far too rich for me at the moment
That's exactly how Sony Scott does it.
Posted: Wed Mar 20, 2013 1:39 am
by JC120
I figured so. That's how it is with the racing cams for the RSV4 minus the conrods.
My pistons and rods aren't stock but they're not HRC. I'd have to talk to Mike Norman who's a member on here and the guy that designed the pistons. Are these slotted so you can get the timing perfect and by any chance do they have the secondary gear to prevent backlash?
Posted: Wed Mar 20, 2013 7:32 am
by Drunkn Munky
There's no slotting these will be direct copies of the hrc cams, there's better cams out there and probably a lot cheaper too but if you want hrc spec then this is your only option so far.
