FZR400 fork will fit on a XJR?
Ugo51
Re: FZR400 fork will fit on a XJR?
Post by Ugo51 »
by the way, what those codes refer to?
I mean, where can I find them written and explained?
So to know for example what code my fork is
Kayla850
Bike owned: Sunn Tzar S2
Post by Kayla850 »
Ugo51 wrote:by the way, what those codes refer to?
Here you go-
http://www.madsi.co.uk/models.aspx
:geek:
www.projection-racing.com
www.pjcfasteners.com
Post by Evilchicken0 »
But why do you want to change the forks .... are they rusted ???
BTW - Yamahas have a model code and we usually use them to refer to a bike ... "it's a 3en2" or a 2TK etc. Yours will have a code too, usually the CDI will have it on the sticker.
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
XJR400 model codes begin with 4HM and then either a single number 1-9 or single letter A-F (I think it's F?) to denote the model year.
Ugo51
Post by Ugo51 »
Here you go-
:geek:
ohhh, thanks
I didn't understand those codes refer to the motorbikes. I though they were the codes for the forks.
thanks. now it's clear
yes, XJR is 4HM. not sure what's mine, probabile 4HM-01...
Ugo51
Post by Ugo51 »
I took some measurements:
fork leght about 76cm
the pitch is 190mm
the discs are 290-300mm (not easy to measure them properly while fitted on the wheel, but I guess it's pretty clear they are not 282, so I assume they are 298)
the rim is 96mm thick, which equals to 3.7inches, so I guess it's a 3.5
last, but not least, I took some pictures
is there any other measurement I can take to identify the fork?
Don't know about the fork
The wheel will have markings on one of the spokes that will give the dia and width.
Kayla850
Post by Kayla850 »
It looks like a 3TJ wheel spindle, and the mudguard mounts look very similar to the TRX850 and TZR250 3MA. Thinking about it, the forks might be the same as the 3MA- they're 41mm and use an 83mm (four pot) caliper.
Ugo51
Post by Ugo51 »
Kayla850 wrote:It looks like a 3TJ wheel spindle, and the mudguard mounts look very similar to the TRX850 and TZR250 3MA. Thinking about it, the forks might be the same as the 3MA- they're 41mm and use an 83mm (four pot) caliper.
the 3MA is the TRZ250, am I right?
so maybe also the SZR660 has the same fork...
I was sure the caliper pitch was 85 but it may be 83. i will check tomorrow
