wont start unless FULLY charged???
Re: wont start unless FULLY charged???
Check your coil windings with a multimeter on the resistance setting across the 3 windings, if they are all within a couple of ohms of each other your probably OK, I think they should be about 50 off the top of my head, if one is miles different take off the cover and check if it has burnt out
Good luck!
Good luck!
- Bike owned: VFR400
1-2 ohms resistance and 50 volts AC when engine running at 5000 rpm measured between pairs of yellow wires, with rect/reg disconnected. Infinite resistance between yellow wires and chassis with rect/reg disconnected.
What he said :-) my wiring book is in the garage . . .
