NC23 Available
Posted: Mon May 27, 2013 5:30 am
CBR400 NC23 Viton Carb Seal KIts
This covers all models G, H, J & K
Sorry for the long production time. Please note that for the J & K models, the spare parts book lists the part number for the vacuum o-rings as being part of the part set 16040-MN4-003, superseded by 16040-MM5-601. However, those Honda parts only contain the o-rings for the fuel tubes and float bowl breather tee pieces. Therefore I have added the 6 o-rings needed for the vacuum breather to the kit, as shown in the picture.
I also had a problem with the production of our fuel o-rings which resulted in them being black instead of green. They are Viton of course, and I have tested them. They will be replaced with our usual green ones in about 3 weeks.
NC29
I need help with the NC29. In the form of a float bowl. If someone can lend me one then I will be able to get them finished and that someone will get a free kit. Takes about 5 weeks to get them back to you from the time the bowl arrives here.
The choke plunger dust caps are made from NBR, the same as standard.
Viton does not release from closed moulds as easily as NBR, so it was NBR or nothing. Even I have to compromise sometimes.
cheers
Blair
NC29
cheers
Blair
