Headlight Issues!
mattchew13
- Bike owned: RVF400
Re: Headlight Issues!
It's bright!magg wrote:The lamp that lights is bright or dull?
- Bike owned: VFR400
As speedy said check the wiring/plug at the bulb that does not light. If you have a multimeter measure the voltages between the chassis and each of the three pins on each headlight connector, what do you measure?
In last post forgot to say the voltage measurements should be made with the bulbs plugged in.
