Re: Heat-related brake light failure.
Posted: Mon Nov 19, 2012 8:29 am
you say things starts to happen when the temp gauge picks up a reading... can it be the thermostat? if i remember correctly, heat and electrical resistance are directly proportional, therefor as heat rises so does resistance, maybe that resistance is causing a short somewhere in the thermostat or in the loom, maybe something is loose?
