Starting problems NC30
mikey65
- Bike owned: 2012 Fireblade HRC NC30 K 1989
Re: Starting problems NC30
starter solenoid is new as is the rec/reglator
- speedy231278
mikey65
taken plugs out checked gaps perfect and re fitted
- speedy231278
- bikemonkey
speedy231278 wrote:Have you checked for a spark when cranking the engine?
mikey65
fuel is getting into the carbs
mikey65
how do i check for a spark?????
mikey65
do i remove a plug then reconnect it to the lead then make sure it is connected to a good earth then turn it over.
- bikemonkey
Pretty much I think.
Google it first on what exactly you should do, probably quite dangerous if you don't test them right.
mikey65
found out how to do it will try that then.
