Re: Winter Tidy Up.
Posted: Thu Oct 25, 2012 12:27 am
Take a deep breath and stay cool,lol. ie fit new air filter and clean rad, flush it out and refill with new antifreeze.
http://www.400greybike.com/forum/
The discs arent warped. You can feel warped discs when you brake. And these are not warped. What made you think they were?xivlia wrote:maybe the brake discs? could be warped, my friends uncle failed his MOT because his 3 year old Megelli 125r had warped front disc, still a fail even though it was roughly about 1-2mm of warp, and you cant see it with naked eye unless you took it out and inspected it, or by spinning the wheel and seeing if it touches the brake pads.
Went a bit better. New rads! £100 quid chinese jobs, but do the trick! Filter was dead on when I took it out. I think its the only thing the previous owner replaced.spooky wrote:Take a deep breath and stay cool,lol. ie fit new air filter and clean rad, flush it out and refill with new antifreeze.
The service limit on an NC30 is 0.3mm. I'm surprised that the bike could be ridden properly with that amount, and if it could, I would have though half the nuts and bolts would have vibrated loose!xivlia wrote:my friends uncle failed his MOT because his 3 year old Megelli 125r had warped front disc, still a fail even though it was roughly about 1-2mm of warp
not sure if it was 1-2mm but it was noticeable when looking down at it from an angle. i didnt actually measure it, it was just a assumption.speedy231278 wrote:The service limit on an NC30 is 0.3mm. I'm surprised that the bike could be ridden properly with that amount, and if it could, I would have though half the nuts and bolts would have vibrated loose!xivlia wrote:my friends uncle failed his MOT because his 3 year old Megelli 125r had warped front disc, still a fail even though it was roughly about 1-2mm of warp
