Page 2 of 2
Re: Found my leak
Posted: Wed Oct 10, 2012 11:20 am
Sam-NI wrote:Was losing a quite a bit of oil. Checked all the usual places. Then found this.
Nice!
You only need one stick but this will repair it if you dont mind keeping it as is (wrong and tatty)
http://www.ebay.co.uk/itm/Lumiweld-10-R ... 0531564152
Re: Found my leak
Posted: Wed Oct 10, 2012 11:51 am
by Sam-NI
Well, when i'm finished with this piece of chewing gum, I might stick that on. Xivilia said it should hold.
Re: Found my leak
Posted: Wed Oct 10, 2012 2:24 pm
by Delboy
Yes but it needs to wriggly's gum as it has a higer heat tolerance over other brands
Re: Found my leak
Posted: Wed Oct 10, 2012 2:42 pm
by Sam-NI
And you can also use the tin foil from wrigglys to camoflage the chewing gum weld, to retain your factory finish. So i'm told.
Re: Found my leak
Posted: Wed Oct 10, 2012 3:00 pm
by speedy231278
If you use a cold flame, you can use the welding pack from eBay to fix the cover while on the bike without risking setting fire to the oil! :-)
