Page 2 of 2
Re: Clutch Lever Reach too Long
Posted: Thu Oct 04, 2012 9:31 am
by porndoguk
In
Out
Shake it all about ;)
Posted: Thu Oct 04, 2012 9:38 am
by CB 4
HI try ebay item 330803667252 hope that helps see if breaker will include a clutch switch connector will measure the span on my bike so u can compare with the other levers shown reg c
Posted: Thu Oct 04, 2012 10:40 am
by speedy231278
I'm sure that my standard lever is one heck of a lot closer to the bar when in and out than that. I have mine set up so there's not a massive amount of movement required, but that looks more like a switch! I'll never forget the time I got the bike back after a service and the play had been adjusted rather badly. I think in and out were about three fag papers apart. Looked like a right wally when I kept stalling trying to get the bike away from the workshop until I adjusted the cable.... lol
Posted: Thu Oct 04, 2012 11:03 am
by missis sumner
I had the same problems with my NC30 when I first got it. I replaced the standard lever with a shorter Titax adjustable, but it really didn't make an awful lot of difference. I think I've just got used to it now.
Posted: Thu Oct 04, 2012 7:09 pm
by CB 4
Goodevening my lever appears to be about 50mm from bar measured the same way as above photos at its min set up thx craig.
Posted: Thu Oct 04, 2012 7:32 pm
by Morespeedvicar
Cant you just slacken the cable off a bit?
Posted: Thu Oct 04, 2012 7:42 pm
by Debbie
Hi, thank you but i've found one Blacks. The lever and bracket off a ZZR600 apparently fits so going to try one of those!
Posted: Fri Oct 05, 2012 2:57 am
by johnnie5
you could just buy stock vfr750/800 levers that come with a span adjuster
