Page 2 of 2
Re: WHERES MY SHIM
Posted: Thu Sep 06, 2012 6:53 am
by chuchu20
How difficult is it to remove that bolt on the outside of te engine?
Re: WHERES MY SHIM
Posted: Thu Sep 06, 2012 7:37 am
by vfrman
Easy once the carbs are off..10mm wrench IIRC.
Re: WHERES MY SHIM
Posted: Thu Sep 06, 2012 10:40 am
by scooble
happened to me once, but the engine was on the bench, so I had to turn the engine upside down and 'shake it out'. Luckily, the engine was pretty dry so it didn't stick to anything.
Re: WHERES MY SHIM
Posted: Thu Sep 06, 2012 11:24 am
by Smev
Just done the valve clearances on my NC.
Didn't drop any and did stuff rag into all possible holes that the shims could fall into.
Better be safe than sorry.
Re: WHERES MY SHIM
Posted: Thu Sep 06, 2012 2:21 pm
chuchu20 wrote:I'll probably search around my work area again tonight.
If no luck how do I take the gear that drives the cams out? Is it the 4 nuts around it.
If that doesn't work I'll probably take the sump out of the right side engine casing.
I took my cam gears out, was a total waste of time for me.
As VFRMAN said theres 4 bolts and one in the centre... the rear cylnder one is a bastard to get to without removing the water pipe in the middle (and you would ideally want to replace the rubber gaskets you disturb) much easier to get clutch / sump off.
Re: WHERES MY SHIM
Posted: Thu Sep 06, 2012 2:56 pm
by vfrman
Oh yeah, I totally forgot about that damn pipe being in the way!
Re: WHERES MY SHIM
Posted: Mon Sep 10, 2012 1:57 pm
by chuchu20
Hey guys so finished the valve clearance the other day.
Thanks for all your help, i took off the right side engine cover and found the shim down in the sump.
Re: WHERES MY SHIM
Posted: Mon Sep 10, 2012 1:59 pm
by vfrman
WOO HOO!
Lesson learned, huh?
Re: WHERES MY SHIM
Posted: Mon Sep 10, 2012 2:32 pm
by amorti
vfrman wrote:WOO HOO!
Dude, your sig is nearly half a page. Do us all a favour and slim it up a bit please? If you must use this space to mock a fellow member, you can always do it without Quote tags and multi linefeeds, but I would argue it's bad form particularly from a mod.
