Re: Can you see what it is yet
Posted: Sat Sep 08, 2012 10:23 pm
Not many pics of this bit.
I ordered a box of bits ... they arived and I've cleaned up the brakes front and rear. new pads in and bled.
One thing I remember from my last 3TJ - why do they put that stupid thing on the master cylinder reservior ??? the clip with the nut and bolt that seizes solid .... I cut it off.
Found out the back disc is warped but then when I came to undoing the disc bolts one rounded out, still it's a good excuse to use the angle grinder. A few minutes with the grinder and a bit of whack and the disc is off the bolt stub got unscrewed with molegrips.
cleaned up the wheel and put the new sproket on. I was going to use some nice pro bolt sprocket nuts but I orderred the 600R ones and they're the wrong size. I had some new flange nuts which fitted so I used them and sent the others back. The chain tensioner nuts are the same as the sproket nuts and I had some new bolts the originals were bent.
So maybe now onto the frame.
