Page 2 of 2
Re: Oh ffs, I think my rear wheel bearing is knackered !
Posted: Sun Aug 12, 2012 6:52 pm
by royster81
Have you bearing codes mate of the ones you got and the seals.
Posted: Sun Aug 12, 2012 7:33 pm
by leef82
the needle bearing is a 50x62x25mm and the dust seal is a 50x62x5mm (one of),
the other is (6908 2RS) 40x62x12mm you want two of these and one seal at 40x62x5
make sure to keep the joining seal off the old 40x62x12s unless the bearing supplier can get them,
you will also need to pop out the plastic cover on one side of each of them so you can join them together with ther joining seal if that makes sense....
hope that helps
lee
Posted: Sun Aug 12, 2012 8:53 pm
by royster81
Leef82 mate your a fucking star !
Posted: Mon Aug 13, 2012 8:53 am
by royster81
Last night a mate called up and we set about stripping an rvf swing arm that I got the lend of so I could borrow the hub until I could get mine repaired or replaced.
I grabbed the rear wheel to show him the play in the hub but because he was on the exhaust side he was able to tell me the WHOLE swing arm was moving in the frame. It turns out the castlenut had become loose and the arm was pivoting in the frame.
We loosened everything off then tightened it all back up correctly and it appears to have sorted the movement. Result !
Cheers for the help guys
Posted: Mon Aug 13, 2012 10:11 am
by vfrman
What luck! How pissed would you have been if you would have done the bearing and the problem wasn't fixed?!
Posted: Mon Aug 13, 2012 10:40 am
by royster81
I would have been incredibly pissed off !! Lol
At least we have bearing codes for new bearings, should we need them......
Posted: Mon Aug 13, 2012 11:12 am
by hannakournikova
Good that it was a simple fix
Posted: Mon Aug 13, 2012 11:33 am
by royster81
Too right it was good, but I rang everyone in my mobile who I thought would have the swing arm tool and in the end stu and I drove to dromore to get one.
Posted: Mon Aug 13, 2012 1:10 pm
by vic-vtrvfr
royster81 wrote:Too right it was good, but I rang everyone in my mobile who I thought would have the swing arm tool and in the end stu and I drove to dromore to get one.
Unfortunately I'd had a little drinky by the time you rang or i couldve run it down or met you halfway.
Sorry I wasnt more help!
